Small pulsewidths calibration
vw_chuck
Post by vw_chuck »
Has anyone calibrated their small pulsewidths cals? I flowed my injector from the dead time up to 2 ms in .1 ms steps and have the curve which makes a big S in some areas. Now how is my curve which is cc/pulse on the y axis and milliseconds on the x axis used to fill in my small pulsewidths tables which have milliseconds on the x and Y axis.
Should the small pulsewidths table be cc/pulse on the y axis????
Thanks for any help on this.
elutionsdesign
Re: Small pulsewidths calibration
Post by elutionsdesign »
It is set up so that the x-axis is what is actually flowing, the y-axis is what you have to set your injector pulse width TO in order for it to flow the x-axis amount. Example, 750 cc/min injector or 750 ml/min is 12.5 ml/second. If the world was perfect then setting the pulse width to 1.0 mS would give 12.5 ml/sec*.001 S or 0.0125 ml fuel. But you being smart do a calibration and find that you actually get 0.0125 ml fuel when the injector pulse width is set to 1.2 mS, so for that data point x is 1.0 and y is 1.2, both in mS. Obviously you can't accurately measure 0.0125 ml, everything is averaged over many injections, but you already knew that.
Graduate of EFI University.
vw_chuck
Post by vw_chuck »
I understand the theory above and I have been trying to figure out just how to calibrate this from a graph that is milliseconds on the x axis and cc/pulse on the y axis for the better part of the afternoon to no avail. As far as I can tell this feature is uncalibratable. How would you ACTUALLY go about calibrating this, not just theory?
Yves
Post by Yves »
I'm going through the same issue here. I can calculate the fuel flow per pulse but where do I go from there ? Figure out at what pulsewidth it flows the same as theoretically ? ?
