Hey guys,
I need your help pls, on my megasquirt 3 the ouptut voltage on every single PWM output chanel is only 0-1.5V.
What I need is 0-5V. Is there an option in the megasquirt software to turn the PWM-output voltage from 0-5V?
Thank you very much!
PWM Output Voltage too low
Re: PWM Output Voltage too low
Nobody else is biting on this, so I will try to get it moving. I haven't used PWM (with the MS system), but this statement doesn't look right to me:
" on my megasquirt 3 the ouptut voltage on every single PWM output chanel is only 0-1.5V."
I'm pretty sure PWM of voltages sources up to battery voltage (12-15V) are available from MS, dependent more on wiring than software settings. Tell more about what you are trying to do, what outputs (names, pins) wanting to use, what devices wanting to drive. I think this is a wiring issue, not programming.
PWM outputs are ground switched; you need to add a pull up resistor.
