Hi:
I am attempting to install a driveshaft speed sensor on my RWD race car. I have a Racepak split collar mounted onto the differential yoke. It is aluminum with two magnets embeddid into it.
What kind of sensor do I need to get?. I would prefer not to buy the Racepak sensor ($150). Is there a generic sensor I could use?
Hall sensor for driveshaft speed
1973 Dodge Dart Drag Car
5.7 Hemi
76 mm T6 Turbo
90 mm throttle body
MS3x
9.47 at 144 mph
5.7 Hemi
76 mm T6 Turbo
90 mm throttle body
MS3x
9.47 at 144 mph
Re: Hall sensor for driveshaft speed
You could certainly make one easily and cheaply if you have some fabrication skills. You get a suitable sensor IC and mount it in a tube or screw using epoxy like "JB Weld". We can provide details if you want to go that route. Lots of folks here have done that.
thanks.
I tried a mopar crank sensor, but it wont work. I need to find a sensor that will trigger from the magnets and not a tone wheel.
5.7 Hemi
76 mm T6 Turbo
90 mm throttle body
MS3x
9.47 at 144 mph
5.7 Hemi
76 mm T6 Turbo
90 mm throttle body
MS3x
9.47 at 144 mph
I remember msd selling a magnet based crank trigger for a gen 1 small block
Maybe they can sell just the sensor?
Well, they do but it's $150 and I'm cheap!
5.7 Hemi
76 mm T6 Turbo
90 mm throttle body
MS3x
9.47 at 144 mph
5.7 Hemi
76 mm T6 Turbo
90 mm throttle body
MS3x
9.47 at 144 mph
Do what Bill said if you want to be cheap. Likely around $1 for the bare hall effect sensor.
