Hi guys,
could you have a look at my tooth log? I've really strange sync lost. The car runs fine, as long as oil and water is not hot and I don't rev it all the way to 6500rpm. Once it started I've problems in the rev area between 1000-2000 and 6000-65000. Is it possible that the vr circuit is sattureted because my vr sensor voltage is very high (more than 150V).
Log is available here.
https://dl.dropboxusercontent.com/u/432 ... .14.09.msl
Any help appreciated.
Thanks julian
Need help on vr sensor sync lost
Re: Need help on vr sensor sync lost
put a 10k 1/4w resistor in series in the positive crank signal, if then you can't get cranking rpm try a lower value of the resistor, and make a composite log if you still have problems.
Megasquirted engines: 4g63, k24a2, b16-b18, duratec, ecotec, fiat 8v-16v, modular 4.6 32v, 1fz-fe, fiat 5cil 20v, Opel corsa, G54B, VW AG, 2ZZ-GE.
https://www.facebook.com/Bartonefi
instagram: @bartonefi
Thanks for your help!
It working perfect now.
Regards Julian
Regards Julian
