Hello,
I am wiring a GM tpi setup with hei8 and a base ms3 3.0. I wired the jumpers per the manual but tuner studios doesnt have the proper ouput options for Spark A output pin = "D14" and for GM HEI/DIS options the only option is "GM bypass on spark B. I am a bit stumped right now and cant seem to find anyone that may have run into the same issue. Has anyone else run into this? Should I jumper the board different for MS3?
http://www.msextra.com/doc/pdf/html/MS3 ... e-1.3.html
Thank you
GM Hei 7/8 with MS3 help
Re: GM Hei 7/8 with MS3 help
On MS3, that setting is "LEDs spark".
Awesome, thank you Matt! Do you think the manual can be updated?
I'll pass this on and see if this can be fixed soon.
