ms 3.57 ls1 board pics > please spark
i have my ms 3.57 running my tpi 350 engine. but i want to swap it for a 5.3 engine. its been a long time seen i have touch my megasquirt. If any one can post pictures on the modification to the board to run the ls1 coils
Re: ms 3.57 ls1 board pics > please spark
Just use the MS3X spark outputs. See these links.
http://www.msextra.com/doc/pdf/html/MS3 ... .3-76.html
http://www.msextra.com/doc/pdf/html/MS3 ... .3-86.html
http://www.msextra.com/doc/pdf/html/MS3 ... 3-161.html
do you have the ms3x option on your ms3 ecu. if so then it will be a fairly straight forward/easy change over. if not then you need to purchase the ms3x board and harness for your ms3 and simply follow the directions.
I have the basic ms3.57. I cannt find goid articles(pics) on the 3.57 board. I have seen tons on microsquirt v3
MS3X would be the easy option. But if you want to put mods on the main board instead, see the MS3 base / V3.57 hardware manual:
http://www.msextra.com/doc/pdf/MS3baseV ... re-1.3.pdf
Sorry. Its been a long time seens I messed around with my ms. I just was reading about the ms3 board. I guess that is he easies option.
nevermind . i have to get the daughter board to install the ms3x.
