Oscillation on idle hot restart
I need help with oscillation on idle hot restart, The megasquirt was Dyno tuned in February and it ran great in all aspects till about a week ago. If I stop the car for about 10 minutes and then I restart the car it starts oscillating, it only last for a couple of minutes before it settles back to normal. I have change the ASE as best as I could (was not to sure how and what to alter) and it made no difference.
I am begining to suspect the Idle Speed Control Valve.
Could somebody be so kind and have a look at my Megalog and current tune to see if I have missed anything.
The car is MX5 mk2 1998 1.8l, Running a m45 Mini Cooper superchager , EV14 550cc injectors, intercooler, Pushing 220HP at the fly etc.
Re: Oscillation on idle hot restart
Check the intake air temperature fuel correction, it will probably be pulling too much fuel out as intake air temp increases
I found the default curve too aggressive
Arran
Arran
http://web.aanet.com.au/arran
Hi Arranarran wrote:Check the intake air temperature fuel correction, it will probably be pulling too much fuel out as intake air temp increases
Arran
Thanks for your reply. I am a little green on Megasquirt, could you give me some guidance and perhaps an example?
Cheers Rick
Under Basic/Load settings
