ALS system not working with a switch
I'm just done mating a MS3 standalone ecu to an OEM Mitsubishi Lancer Evo 8 using a home made patch harness with a Denso connector..
Everything works great: fans, launch control, tacho, fuel pump priming, even ALS, but it's only turned on and off from the Tuner Studio software, i mean I can't leave it "On" in TS and control it by a Switch to ground on "Datalog In" let's say;
Another problem is the Stock Mitsubishi Stepper Idle valve doen't work, it has 6 pins , the 2 in the middle are +12V the others are for the 2 servo coils, didn't work.
Still have the A/C to setup and the Vehicle Speed Sensor...
Been a great project so far
Re: ALS system not working with a switch
Matt Cramer wrote:
I see you are using the 1.4 beta code - do you have the same problem on 1.3.4 release firmware?
Yes,Matt Cramer wrote:I see you are using the 1.4 beta code - do you have the same problem on 1.3.4 release firmware?
I tried them both, no difference
look at status2 in the log, the whole time its jumping up and down = 4. something to do with 'launch in' wonder if thats your issue.
Yes Right, I see that all the time while the clutch pedal is disengaged !grom_e30 wrote:look at status2 in the log, the whole time its jumping up and down = 4. something to do with 'launch in' wonder if thats your issue.
When I depress the clutch pedal, It lights ON and stabilises and Launch control works
wonder if thats stopping the anti lag working
[quote="dochka"Another problem is the Stock Mitsubishi Stepper Idle valve doen't work, it has 6 pins , the 2 in the middle are +12V the others are for the 2 servo coils, didn't work.[/quote]
Take a look at the manual, page 45:
Other manufacturers use 5- or 6-wire steppers which are uni-polar.
These are usually wired as shown in the schematic below, with a center tap on each of two windings. In use, the
center taps of the windings are typically wired to the 12V supply, and the two ends of each winding are
alternately grounded to reverse the direction of the field provided by that winding.
Take a look at the manual, page 45:dontz125 wrote:[quote="dochka"Another problem is the Stock Mitsubishi Stepper Idle valve doen't work, it has 6 pins , the 2 in the middle are +12V the others are for the 2 servo coils, didn't work.
[/quote]Other manufacturers use 5- or 6-wire steppers which are uni-polar.
Thanks Dontz,
Yep, I used that schematic, it's listed in the mitsubishi manuals too...
