Adding a resistive sensor
Schuyler
Post by Schuyler »
So I am attempting to add a resistive coolant temp sensor from a saturn for my oil temp. I had found it online, on msextra I think, where people recommended using it. However, my understanding was I just put 1 lead to ground and 1 lead to an analog input (EGO2) on the ms3x card. Set to GM calibration. Did not work, and the values are crazy, and jumped a lot. Do I need to a 12V pullup with a 1k resistor to make this work? Or is there something else I am doing wrong?
elutionsdesign
Re: Adding a resistive sensor
Post by elutionsdesign »
Ground is sensor ground, correct? Back to the MS unit?
Graduate of EFI University.
kjones6039
Post by kjones6039 »
Schuyler wrote:just put 1 lead to ground and 1 lead to an analog input (EGO2) on the ms3x card.
I don't know anything about MS3, but I suspect that your ground should go to sensor return, as with all other MS sensor grounds!
I could be wrong, but I don't think so.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
grom_e30
Post by grom_e30 »
did you fit a resistor to the ms3x card??
R65,R66,R67 are optional 'bias' resistors on the analogue inputs EXT_MAP, EGO2, SPARE_ADC respectively.
These would be typically used when connecting a resistive temperature sensor to one of the inputs. For
standard calibration, use a 2.49K resistor with a GM style coolant or air temperature sensor.
billr
Post by billr »
You are going to need a 2490 ohm pull-up to the 5V ref; you need to build an input circuit similar to that existing for the (standard GM) CLT and MAT sensors. Look at the V3.0 mainboard schematics.
Ah, I see I was too slow in typing! Besides, the rely above is more thorough.
Schuyler
Post by Schuyler »
Thanks! I will add the resistor to the board. I did not use the sensor ground... Maybe I should consider moving the ground.
