buzzing noise from crank hall sensor
I just wired up my hall sensor and noticed that it's buzzing. Is this normal ?
Re: buzzing noise from crank hall sensor
I doubt it!!! How do you have it wired, exactly?Yves wrote:I just wired up my hall sensor and noticed that it's buzzing. Is this normal ?
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Yes, quite positive :
Red to 5V
black to ground
Black/white to signal.
It's like an high tension electrical sound of sorts.
I measured the voltage between signal and ground at various tooths and gaps and it seems to work.
Red to 5V
black to ground
You've got me curious now! I this occurring when the engine is running or off (or both)?
Engine off.kjones6039 wrote:You've got me curious now! I this occurring when the engine is running or off (or both)?
I gotta ask... how loud is this "buzz"? When the engine is running, do you think there is really a chance you could hear or feel it over the normal engine sounds and vibrations?
No not that loud. I'm not concerned about the noise, I just not sure that it is supposed to do this.
