I was hoping that I could double up the use of my shift light for Check Engine Light duty as well.
When I set it, I get a conflict on the outputs.Is it possible to use the shiftlight (NOS2 Out in my setup) for CEL as well?
Would it be possible through other means?
Thanks in advanced
Shift light double as CEL
Re: Shift light double as CEL
It could probably be done with 2 outputs on a single lamp but each MS output can only have one function.
Support the developers!
