Car will start and idle good when cold. When I start the car after it is hot it will start then die. I can do this several times before it actually stays running. When it does stay running the idle will hunt for some time before it settles down. Once it settles down it is fine. Car will drive fine and idle fine until I shut it off and restart it. I have played with the ASE percentage, ASE taper, Crank to run taper, WUE but I am still have issues with the hot start. I have a datalog of me trying to start it a few times to show what its doing. I also noticed my accel enrichment is coming on and going to 100%. I don't know why its doing this because I don't have to touch the gas pedal when I start the car. When the idle settles down the accel enrichment is still at 100%. ???????
Here is what's in the car
1998 Ford Explorer block 347 ci
AFR 185 heads
Holley Systemax II intake
Comp Cam XE264HR
Mac 1 3/4 shorty headers
75 mm TB
42 lb/hr Bosch injectors
Walbro 255 lph
Ford Explorer ign coils
MS3 w/ MS3X expansion V3.57
LC 2 wideband (2)
4R70W with Baumann Opti-Shift controller
Precision Industries lock-up convertor 2800-3000 stall
Hot start issues ???
Re: Hot start issues ???
Try more ASE on hot starts.
Thanks Matt. I don't see ASE on my Megalog. Is it labeled under something else?
It is included in the warmup correction.
