I have a question about the overrun fuel cut settings.
You can specify the overrun spark timing to a fixed number, but is it also possible to have the normal spark timing as commanded from the spark table and not use this fixed number?
The timing settings are not really clear to me and the manual is very short about the overrun fuel cut.
Overrun fuel cut spark timing
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Innovate LC1 wideband lambda sensor
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Re: Overrun fuel cut spark timing
Looks to me like you can simply leave that spark-change function set to "off". What am I missing?
You probably mean the "ignition timing transition" . I initially thought this just controls wether there is a transition time or not, but you might be right.
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Yes, that's what I was looking at. Never tried it personally.
