Crank taper timer
Crank taper timer
I've noticed that the crank taper timer doesn't seem to work at least with closed loop. My start crank pwm dwell only stays for maybe 2 seconds and then goes imidiatly to my in tial dwell from the initial settings. This isn't really a problem I guess but I have the crank taper set to 10 seconds and it's not working how I think it should.
Brent Savage
life behind the zion curtain
90 audi RS2 20VTQ 6sp MS3, MSX COP and Sequential and now MAF
87 Scirocco 2.0 ABA 16v EIP tubular cast MSII COP
86 Audi 4K20VTQ MSII
90 Audi 90 sedan 3.6l DOHC V8TT (project car)
89 VW cabbie (bitch basket) 2.0 ABA Turbo MSII
Re: Crank taper timer
I've messed with ramp to target and crank taper. Doesn't affect it one bit. It starts and within a second it goes right to the initial value dwell until cl kicks in. This can't be the way it is designed.
Also should have posted this in development if a mod could move the thread.
Brent Savage
Taper only works in open loop
Support the developers!
