i had an idea for closed loop fuel pump control but ran into an issue sensor wise.
my idea was to use a return style system with a flow sensor on the return and try and maintain a trickle in the return line to keep pump speeds down and eliminate the need for a large fuel return line. the problem i ran into was all the affordable sensors i have found are the type that "tick off" volume, basically a pulse for every metered volume.
http://www.futurlec.com/FLOWFUEL30L0.shtml
looking through tuner studio this probably wont work as it is voltage based not frequency.
Re: idea for closed loop fuel pump control
I would think you can set up a generic sensor input or VSS input and base a closed loop PWM output using the input.
Graduate of EFI University.
Use a frequency-to-voltage chip? Those have been around for a long time, can probably do any scaling you need as well as the F/V conversion.
Have you just thought of running a fuel pressure sensor and going returnless?
Agreed - something like an LM2907 / 2917 (with careful selection of function resistors and caps) should work quite nicely.billr wrote:Use a frequency-to-voltage chip? Those have been around for a long time, can probably do any scaling you need as well as the F/V conversion.
