I am looking to find a way to have fuel pressure monitored in the cabin, as well as logging it on the MS3X.
I am looking at buying this gauge: http://www.speedhut.com/gauge/GR-FUEL-0 ... --warning)
My question is, Is it possible to purchased this unit, and tie the outputs of the sensor to both the gauge, and the MS3X????
Piggybacking gauges with Analog input???
1968 Dodge Charger, 446ci 513HP/542ftlbs,Full sequential fuel/Spark using MS3X. Jeep CPS, Ford Crank sensor, 36-1 wheel, Coil near plug with D-585 ls2 coil packs. Edelbrock pro-flo intake, 600cc injectors, GM MAP, TPS, IACV, CTS, MAT. 92mm Throttle Body.
Re: Piggybacking gauges with Analog input???
Probably. Most sensors like that are 0-5 volt and the signal is easy to split.
Perfect!
I will report back as to how it goes.
how did this work for you?
I'm about to try a similar thing but don't want to build it into the harness unless it's known to work
