I've got the engine running using just the crank sensor - semi-sequential - but I'm not sure what settings I need to get the cam working correctly. Can anyone offer some suggestions?
1ZZ-FE Crank 36-2 Cam 3-1
Re: 1ZZ-FE Crank 36-2 Cam 3-1
That's 2JZ VVTi mode.
Thanks for getting back to me so quickly
When I change the mode to 2JZ VVTI do I enter the Tooth #1 Angle in to the Trigger Angle/Offset box?
No, the tooth#1 angle is built in. The offset is used to make any small adjustment +/-20 deg that may be necessary on your engine.monsi wrote:When I change the mode to 2JZ VVTI do I enter the Tooth #1 Angle in to the Trigger Angle/Offset box?
Hi James,
That worked perfectly Thanks
Interested in installing MS3 on 1ZZ-FE too, gathering info. As per service manual cam wheel is 4-1, so it has three teeth each 90 degrees apart. As I understand, it's not the same as 2JZ vvti, can it really work correctly in 2JZ VVTI mode?
