Sync loss & no tach output
I just moved from MS2X to MS3X Rel 1.2.4 and TS rel 2.4 and my datalog shows sync loss and my dash tack does not work. I have RPM in TS and all sensors seem to be reading, but tooth logger shows problems.
I am running a boat with GM 4.3L HO, with TBI and Ford EDIS VR and coil LESS the EDIS module. So I am using MS3 base fuel and MS3X spark with JBPERF 4 channel board to fire coil.
Attached are datalogs before noise reduction, tach rejection and input rejection. These seem to help the problem looking at the tooth logger.
So my question is will the VR Pots being adjusted help the issue?
Is there some sensitivity in these settings that is keeping the MS3 from putting out the Tacho signal?
Should I be looking somewhere else?
Re: Sync loss & no tach output
Here are 2 more datalogs with noise filter and no filter.
i think the pots should help with the noise issue, as to the rev gauge what out put are you driving it from? if its the one on the ms3x did you install the pull up jumper?
Thanks for the help.
Yes I did install the pull up jumper on the #X board, I think it was. If there is more than one - I don't remember but one.
One question - my ECU is pretty inaccessible in the boat - so to adjust the pots do you adjust and then run a tooth decoder and look at the datalog and then repeat? Bob Pendleton.
if the ecu is not easy to get to your theory of adjust log and check may be the best solution. your tacho was running fine with ms2?? did you re wire it to the new output on the upper db37 connector? there are 2 jumpers on the ms3x card jp3 is the pull up for the tacho. if it was working before why not use the output that did work and change the settings in the msq to use that output.
Thanks Grom for the help.
I have checked the manual for the jumpers and have no cam input, so I jumpered only the Tach output pull up.
My tach output for the MS2X was a diy in the proto area and worked pretty well. I would rather not diy the output if I can help it.
I also reset the pots according to the manual and will reinstall and see how the tooth pattern looks.
Is there any way of knowing whether to adjust both pots or just the first and not the second?
Thanks again, and I will keep you posted.
Bob Pendleton.
Bob Pendleton.
there is a guide on the diyautotunes web site about adjusting the pots.
Thanks, Grom, for the info. I will check it out right now. Bob Pendleton
I spent several hours trying to adjust sensor and could only make it worse, so I thought I would try another sensor and bought a Hall sensor from DIYAutoTune and have installed it.
But I have no fuel output.
Again I spent several hours adjusting pots and have clean signals, but still no output.
Sync loss is down, but obviously I don't know how to adjust the pots.
See attached msq and logs
Really frustrating.
from the logs you just posted it looks like you need to change the 'ignition input capture' try falling edge.
Grom, thanks for the help.
Here are more logs. I think I am getting closer, but not there yet.
Tooth logger looks OK but Comp log still not correct - am I right?
I have changed the input capture - to falling. Thanks again. Bob Pendleton.
the composite log is pretty short but looks ok there is a tiny bit of sync loss at the start(the red marks) for the first rotation of the engine or so but it syncs up ok after that and stays synced for the rest of the log.
Grom, I saw that.
Should I be able to get rid of it totally?
Just adjusted R56 too far and got no Comp log.
Will go back, but will R52 help with the sync loss?
its quite normal to have a small amount for the first rev of the engine until the the ecu fully syncs up.
Thanks for all the feedback.
Does the tooth log look OK?
I will try to see if it will fire.Thanks again. Bob Pendleton
yeah both looked pretty good
IT FIRES!!!
Now to make it idle.
R56 set at 4CW and R52 at 2CW with 12V power.
Thanks, Grom, I never would have done it without you.Bob Pendleton.
nice one glad you got it sorted.
