i have setup a loop and i would like to know if im heading in the right direction. my goal is to have boost table switching when MAT exceeds a set threshold. i went to programmable ouputs, enabled LOOP1 power on value off active value ON then i configured Mat > 35 hysteresis 1.
i then went to boost table switching and enabled it and set it to enable on Loop 1. i then configured the secondary target table to a lower boost.
is this correct?
secondly how do i enable an indicator to indicate which boost table is currently in use ? like an indicator that tells me when boost table 2 is active.
thanks.
2 questions about loops and ts
Re: 2 questions about loops and ts
Yes, that's how to use the LOOP mode. I'm afraid there is no way to set an indicator for this directly, although you could set the MAT gauge to change colors at the activation point.
