Did a bunch of reading and just want someone to double check this plan for adding 2 inputs for VSS. Inputs will be a 0-5v switched signal.
VSS1 - PT4 with a 1k pullup to VCC.
VSS2 - Use this circuit to connect my second signal to JS10
All other inputs are in use right now.
Solid plan?
VSS input clarification
Re: VSS input clarification
Looks ok.
and what is the maximum frequency on these inputs?
The input pins are polled at 20kHz, but that's for both edges and there's in inbuild noise filter, so probably around 2500Hz. However, both of those inputs are connected to timer pins and can operate in higher speed interrupt mode.
