Cranking taper curve question
Was playing around with the cranking taper curve today.
I was wondering what is meant with "events" in the curve. Is this engine cycles, or ignition pulses? Tooltips are not exactly clear on this.
Rene
Rene
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Innovate LC1 wideband lambda sensor
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Re: Cranking taper curve question
I'm pretty sure it is ignition pulses, all of them, every cylinder adds to the count.
I would say so, but it is very unclear. The manual is also not clear on this.
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
"Events" always refers to ignition events.
And the term "ignition event" means one ignition spark, or an ignition cycle (=8 pulses for a v8 for instance)?
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
One spark.sd1nl wrote:And the term "ignition event" means one ignition spark, or an ignition cycle (=8 pulses for a v8 for instance)?
Ok, thanks
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Strange thing is though that when I set the "ASE count units" to "cycles", in reality this is "ignition events"
And when I set the "cranking fuel rate" to "every event" , the tooltip says this means every "tach event"
It is kind of confusing.
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Same thing.
