wasted COP question
hobieboy
wasted COP question
Post by hobieboy »
I have a question of testing with wasted COP -
I have wired the ignition in sequential COP configurations (i.e. using Spk A-F each driving a COP coil for a cylinder), and MS3/MS3X is configured as COP right now.
If I change it to wasted COP, will MS3 simply fires each coil once every crank cycle (as opposed to every other) but still firing them from A-F sequentially?
For background, still chasing a ignition miss/break up problem when I get on boost (only at ~10psi) & RPM >4000. I can't get rid of this problem since upgrading from MS1-extra to MS3/MS3X (during which time I also changed from wasted spark to COP, and batch fueling to full sequential via addition of a hall CAM sensor).
thanks!
grom_e30
Re: wasted COP question
Post by grom_e30 »
if you change to wasted cop it will fire them in pairs just like wasted spark so, a+d, b+e, c+f will be fired together each coil will fire twice per cycle.
Madkaw
Post by Madkaw »
Have you gone back to non sequential-take the cam sensor out- to see if it still breaks up at 4K?
Watching this thread for my 4k missing out issue too.
Steve
1971 Datsun 240z 3.2 L6 1975 EFI intake plenum 60mmTB with 42lb Bosch injectors
MS3x 3.57 Ignition LS1 coils running full sequential
!983 Nissan 720 MS2/3.57 ported efi 26lb Bosch VW 4 tower ignition wasted spark
hobieboy
Post by hobieboy »
grom_e30 wrote:if you change to wasted cop it will fire them in pairs just like wasted spark so, a+d, b+e, c+f will be fired together each coil will fire twice per cycle.
Thanks for the explanation... so I can test without re-wiring the coils/plugs which is great :)
Steve, which thread describes your 4k missing issue?
