After upgrading from 1-3-1 to 1-4-0 just now, I keep getting an error message that Serial Failure due to 3 failed attempts to read data.
I have enclosed a screen shot of the error message - as you can see that TS just displayed the "difference report" and I haven't even had a chance to go through what it is.
This happened when I opened TS for the 1st time after MS3 is upgraded to 1-4-0. TS warned me of wrong ECU signature, then it downloads the appropriate file from efianalytics.com (I am using TS 2.6.19) after I selected update ECU signature. The tune was the one that I was using with 1-3-1. I tried ignore (close) this window and select "Send Current TunerStudio Setting" from TS but it doesn't work.
Appreciate any input of what to do from here.
thanks!
Trouble upgrading from 1-3-1 to 1-4-0
Re: Trouble upgrading from 1-3-1 to 1-4-0
It seems that you have a CAN device in your project. I don't know which device you have but there are a couple of issues with CAN in the v1.4.0 firmware. I would recommend you go with the beta version which corrects those: http://www.msextra.com/forums/viewtopic ... 25&t=59596.
Hi Jean,
Upgraded to 1.4.1-beta per what you suggested and it fixed the problem
I am using one of your IOX/EGT module
Have to see if it works now - battery is dead unfortunately after all the testing done
thanks!
thanks!
