Hi!
Do you guys know the right settings for LS2 coils? High or low out? I've found little on the subject and about halv says high and the rest low.
Thanks!
Also;
Can I have a canbus in that is wires to a relay so that the engine can't start unless the relay is powered?
I want a safety so that the engine cannot be started unless you have your foot on the clutch.
Ls2 coils, high or low? +Canbus question
Re: Ls2 coils, high or low? +Canbus question
Depends on what ECU you have.
Derp...
MS3-Pro
MS3-Pro
1.Going high. Don't go past 4 ms on dwell.
2. Wire your starter relay so one side of a coil recieves ground when clutch is depressed and the other gets +12 from the key once it's turned to 'start'.
Erm... depends on the coils.ekam99 wrote:1.Going high. Don't go past 4 ms on dwell.
I'm currently using the std LS2 coils, w/roundish bodies.
Make sure you set the dwell/voltage table using the GM LS2 table data.
I run 4.3ms, much less than 3.8ms I start dropping cylinders.
6ms cranking.
