Upgraded to MS3X from MS1E (KA24DE) *NO FIRE*
cmj
Post by cmj »
Having trouble getting the car to fire.
Rebuilt the motor over Winter.
DIY 12-1 (24-2) trigger wheel. LS1 coils, (Batch fire.. forgot to run the second trigger DOH!)
Attached is log, msq, and trigger log.
The car ran excellent on MS1E, I upgraded to play with more features, and now i'm stumped.
Any help is appreciated!
grom_e30
Re: Upgraded to MS3X from MS1E (KA24DE) *NO FIRE*
Post by grom_e30 »
you have a rpm signal problem did you change how the main board was set up? maybe try falling edge on ignition input capture.
cmj
Post by cmj »
Jumper J1 is in the 3-4 position. JP1 is in the 1-2 position.1k Resistor across R57. Here is a log with falling edge.
grom_e30
Post by grom_e30 »
falling does not seem to help did you adjust the pots on the main board like so http://www.msextra.com/doc/pdf/html/MS3 ... .4-69.html
cmj
Post by cmj »
Attached is a tooth log. I took the distributor out of the car and turned it at a constant speed with a drill.. The log looks exactly like it should... Right?
I think maybe I have a low battery issue?
grom_e30
Post by grom_e30 »
id say the log looks pretty good, when on the drill did you get a constant rpm reading in ts or was it still dropping to 0.
cmj
Post by cmj »
RPM is smooth, no sync loss.
cmj
Post by cmj »
The car fired right up. Had a battery issue. Thanks for all the suggestions!
dontz125
Post by dontz125 »
cmj wrote:DIY 12-1 (24-2) trigger wheel. LS1 coils, (Batch fire.. forgot to run the second trigger
If this really is a 24-2 cam trigger (and not 12-1+12-1), then you already have what you need for full sequential.
Post by Matt Cramer »
Our cam trigger is meant to behave as a 12-1 crank trigger and needs the second trigger input for full sequential.
