L98 startup
odd boy
Re: L98 startup
Post by odd boy »
many thanks RPM got synchronized, but the car makes a lot of back fire while cranking. I am attaching the file for you review.
what angle shall i dialed for good starting?
58x LS3 startup file.msq
Dookie454
Re: L98 startup
Post by Dookie454 »
you should be able to use a Timing Light while cranking to see your crank pulley.. mark TDC on it somewhere.. that's how I do this type of angle/crank timing setting stuff especially if It doesn't start first try. I blew the starter off the bottom of an engine once, and took a tooth off the flywheel. Now I check timing... much easier to fix.
MS3X on 2010 Camaro LS3 + Whipple @ 10psi + HPT + AEM 30-0333/0334 WB
MS3 Knock Module + JBPerf Dual VR v2.1 (Removed), didnt play well with LS3 DBW Motor, works for VSS.
OLD: 1997 Chevy Z71 Vortec 350, + BOSCH 0261231036 WB Knock Sensor
OLD: LT1 TA 700hp + MS3X
odd boy
Re: L98 startup
Post by odd boy »
it cranks and fires, but doesn't stay more than millisecond.....
any help please.........
nathaninwa
Re: L98 startup
Post by nathaninwa »
Can you post a log? It may need more fuel just after starting to keep running
odd boy
Re: L98 startup
Post by odd boy »
nathaninwa wrote:Can you post a log? It may need more fuel just after starting to keep running
What parameters do u want me to record?
Re: L98 startup
Take a regular datalog as per the Forum help page.
odd boy
Re: L98 startup
Post by odd boy »
2015-09-03_22.13.20.msl
2015-09-03_22.34.02.msl
2015-09-03_22.33.17.msl
nathaninwa
Re: L98 startup
Went to fire mine up tonight, and it will crank and Fire, then die. Then my battery must be to small and cranked it dead so tomorrow I'll get a second battery tied together. I did get a few attempts in tho and crank, fires and dies. I see in ts that it syncs up with no issues at all. But I'm thinking I might try wasted cop tomorrow if sequential only fires and dies
nathaninwa
Re: L98 startup
Got mine to fire today. Won't run in sequential mode, only semi fuel and wasted cop. Must be a poll level phase or crank tooth look up that is wrong
