Was hoping that would fix it... has no effect in open loop. The set DC works as it should. Completely ignores the VSS table no matter what I do. Closed loop pulses the solenoid in accordance with the "Boost Control Bias Table"nathaninwa wrote:You will need the newest beta, 1.4.1 for it to be accurate. Otherwise the gas mph would need to be 3 for 30mph and so on
I noticed on the dat log the "boost Traget 1" sits at 100% the entire time? Is this wrong?
MSQ and LOG here.
http://www.msextra.com/forums/viewtopic ... 31&t=60265
