Does any difference in vss1 and vss2 initiate traction reactions, or is it only when the driven wheels exceed the un-driven by the slip percent? My front wheel sensors have a bit of noise and will occasionally blip above the driven wheel VSS. The driven wheel will never exceed unless there is actual wheel spin.
Also, relating to traction control. I have it set to enable based on an input. I am trying to verify functionality of my switch. I don't see traction input as an available indicator. Is there a software function to verify if the switch is working?
Traction control: VSS slip % clarification?
