Data log - staged injection - seqPW3 = 0
It's been a while since I added SEQPW1 and SEQPW3 back onto the traces displayed in Mega Log Viewer, but SEQPW3 now just reads 0, I'm sure that previously SEQPW1 was primary injection mSecs, and SEQPW3 was secondary injection mSecs.
Duty 1 and Duty 2 give expected duty for primary and secondary
I've posted in the TS section rather that MLV because I'm thinking it may be a problem with the writing of the data rather than the reading.
Any ideas ?
Any ideas ?
http://web.aanet.com.au/arran
Re: Data log - staged injection - seqPW3 = 0
Below shows a log from a dyno run in July, running firmware 1.3.4. The SEQPW 1 and SEQPW3 are correctly showing injector mSecs
This one was taken on the weekend, it is one of a couple of standing start runs down the main straight of Queensland raceway. Firmware 1.4.1. SEQPW3 (and 4) are 0
Please post before and after MSQ and datalog sets.
Done, i've added the msq with its associated data log post,
thanks
thanks
Confirmed, there's something wrong. Looks like it got changed in November 2014. Investigating.
Hi again,
I also noticed that the Duty 1 and Duty 2 can exceed 100%. Should this be possible?
MSL attached, in third gear I get to 104%
It means you've run out of injector, and the MS is trying to hold it open longer than 100%. Unfortunately, that doesn't accomplish anything. This fits with the discovered error of the staged injectors not firing.
That's not the error.dontz125 wrote:the discovered error of the staged injectors not firing.
The found bug is that the REPORTED pulsewidth on the channels is incorrect, the actual electrical pulsewidth should be ok.
Yes, the AFR is behaving. If there was an actual secondary injector problem the car would have had an engine failure by now
Confirmed that this logging issue is fixed in 1.4.2
