When I refer to documentation, I see no mapping for White or Gray cables for a constant battery supply. Is this correct ?
Pin #35 on White cable is switched on 12V source. Pin #19 on the Gray connector is for Digital Switched 12V in (??)
Install ?: No Constant Battery power ?
1992 Mustang Conv,
363" Man-o-War (8.2"Deck), Dart Pro-1,
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
Innovate DLG-1 (dual WB O2)
Ignition LS2 coil on plug (Crank trigger+ Explorer cam sensor)
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
Re: Install ?: No Constant Battery power ?
pin 35 white connector is switched live (power for the ecu)
pin 19 grey connector is for a switched input to activate what ever function its assigned to when 12v is applied to that wire.
no constant live is needed.
Many thanks for the confirmation !
1992 Mustang Conv,
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
