ls1 map sensor pin outs late model
I have recently purchased an as60 gm map sensor, I cannot find any information concerning this sensors wiring connections. my new intake manifold requires using this sensor or finding a plug to fill the hole in the manifold. so I purchased the sensor and plan on using it for map and using the onboard sensor for baro correction. my problem is that I haven't been able to find a wiring schematic that shows the pin outs for this sensor. any help would be appreciated.
Re: ls1 map sensor pin outs late model
A = ground
B = signal
C = VREF
B = signal
C = VREF
thanks Matt. I connected it up and tested the map sensor using a power supply on my bench and checking the out put from the signal wire.. all is well.
Nice, I'm running a similar setup on my '72 Chevy with a 4.8 swap.
