Anti-lag injector placement
Trying to get an idea of a place to put a fuel nozzle upstream from the turbine to help spool the turbo. I was just going to use a fuel nozzle and a solenoid from a nitrous system about 4 inches from the turbine. Will that work? What does most people do?
Re: Anti-lag injector placement
Im not increadibly familiar with the ALS in most cars but from a little reading and a little knowledge of combustion you will need more than just fuel in the exhaust to cause this to happen. There should not be enough o2 left in your exhaust gas to burn fresh fuel injected by itself. What is your plan for air injection? If you dont have one there is an option for tuning the car to run a little rich when not under load and force the aic valve to keep idle up a little. For my own personal what is the drive for an Anti lag system?
94 Pontiac Firebird Formula
5.7L LT1 (optispark)
Ms3+3x
Ms3+3x
Better to spray a shot of Nitrous in the intake to get it spooled. Makes some power and wakes up the turbo.
most people do not inject fuel directly into the exhaust. severely retarding the timing and overly enrichening the mixture is sufficient in most cases, which the ALS code already does.
Ok thank you for everyone's help. I just want to lessen the time because once you bump into the staging beams there's only a second or a second and a half befor the tree comes down.
So the Code uses several strategies For the ALS. What does most people do? When I press the trans brake button my ignition goes to 23° and I usually set the launch KPA at 150. I don't use nitrous oxide. So I'm going just wondering what's the best way?
oh youre talking about staging for drag racing, not antilag as it is usually used.
in that case i would agree with the earlier advice to use nitrous. otherwise you are going to have to figure out how to start spooling things up before you fully stage and lock the transbrake.
That ALS will not work at the starting line?
it will, but not as effectively as the 2 step limiter will. ALS is active only when the throttle is otherwise normally closed, like when coasting or braking.
