Dual O2 sensors with MS3
I'm sure I overlooked it, but I did do a search and found articles relating to MS1 etc. I'd like to run 2 LC2 wideband o2 sensors since I have dual exhaust - I have MS3X, how would I accomplish this? Thank you in advance - Dan
Re: Dual O2 sensors with MS3
wire your second o2 sensor to one of the spare adc inputs on the ms3x card like 2nd o2 or spare adc, select what cylinders are connected to each wide band and adjust the settings in ego options
Ah, got it. I just now saw it in the manual, so I can wire it to EGO2 and be good to go. Thank you for the information, I really appreciate it.
