I had been chasing the problem where as soon as I touch the gas pedal the car would die (http://www.msextra.com/forums/viewtopic ... 34&t=60636). I started this new thread because I seem to be chasing a sync loss problem now which was not the case before so I start this new thread here rather than in the Tuning forum.
In the attached data log, you can see that as soon as I let go of gas pedal, RPM starts to drop, MAP rises. At secL=130, there is a sync loss followed by 2 more in the next 2-3 seconds. I have included the Sync Loss log that I also started and it did capture all 3 sync loss.
Did I read the Sync Loss log correct that the reason for the sync loss is MS3 did not detect missing tooth in all 3 cases?
Is this a matter of adjusting R52/R56 again or what steps should I consider taking to get rid of this sync loss?
I am not sure if it is related but another new problem is fuel pressure - I used to have very steady and correct fuel pressure but as the data log shows, after the sync loss, pressure went crazy. In fact, I didn't include the earlier part of the log - before I start pressing on gas pedal the fuel pressure was as crazy as this and AFR reflected that as it was running leaner (~13.7 as opposed to the ~12.2 in the beginning part of this log).
Appreciate any thoughts and helps!
Help with Diagnose Sync Loss
Re: Help with Diagnose Sync Loss
Unfortunately, I'm not seeing a sync loss in the sync error log. Can you see if you can catch it in a tooth log instead?
Here's another datalog showing same issue and the associated ToothLog.
I think the log says the missing tooth is missing?
Appreciate help with analysis and what I need to look at fixing
thanks!
thanks!
Yes, that catches it. If this is a VR sensor, try a 10K resistor inline with the VR sensor wire.
