Running Dual O2... VE Analyze question
So if you run 2 O2 sensors, how does VE Analyze take and process that information? can it change the fuel per bank?
81 Porsche 928. 5L 16v, MS3X CNP- full sequential
Re: Running Dual O2... VE Analyze question
im curious on this one too
Short answer - yes.
Long answer - open [Fuel Settings] [AFR/EGO Control] , then look at the middle and right columns of drop-down boxes.
Set the number of sensors, then indicate which pin each sensor comes in on. Next, select which sensor is used to control which cylinder. If you are firing batch you can select the bank; if you are running a 16-cyl fully sequential, you can assign each of 16 sensors to each of 16 cylinders. Although, I'm not sure where injectors M-N-O-P are connected; the current code and pin-out eats away at the spark and injector pins to make room for the knock module ...
