Beginning the installation of a Megasquirt system into my twin-plugged 1980 Porsche 930 and am hoping someone here can help with a wiring question.
Along with the MS3Pro, I have a pair of DIY Autotune's IGN-6 coils and a pair of their Quad-Spark modules. I'm not certain whether I should be using all four outputs from one of the Quad-Sparks and the first two outputs from the other, or the A, B and C outputs from each (I'm leaning toward the ABCs).
I've attached a diagram I came up with - here's hoping I can get some solid input as to whether what I came up with will work or if I need to make some changes.
Thanks,
Norm
Porsche 930 Twin-Plug Wiring Question, MS3Pro
Re: Porsche 930 Twin-Plug Wiring Question, MS3Pro
The QuadSparks won't care if you hook them 3+3 or 4+2; the driver channels are independent. What's the firing order?
The QuadSparks won't care but the ECU must be wired such that the first 6 channels are used (A to F). The way you have them there won't work for a 6 cylinder. You can have A-C to one QuadSpark and D-F to the other one or you can have A-D and E-F or whatever combination is more practical to you as long as you use outputs A to F.
Thanks, Jean. I was about to respond that I had used outputs A-F but figured I might as well double check. As you already knew, I hadn't, somehow substituting G for D. If I swap D in for G will that do it? Thanks again for pointing out this glaring error on my part.
As long as you use A-F and wire them to the correct cylinders for your firing order, you'll be ok. So yeah, use D and not G.
