I'm starting to experiment with dual WBO2 sensors and have a question about how that control works with sequential and also about the assignment of the knock sensors:
See the attached log...I'm running sequential fuel and dual knock sensors, and the only fuel variable I can see differing is that Seq PW1, Seq PW2, and Seq PW3 are different from Seq PW4, Seq PW5, and Seq PW6. The engine is a H6 and the firing order is 1-6-2-4-3-5. I have EGO1 monitoring cylinders 1-3 (left side of the engine) and cylinders 4-6 (right side of the engine) monitored through EGO2. Can anyone confirm that the numbers in Seq PW1-6 here are the actual cylinder numbers and not referring to the firing order instead?
On the Knock Sensor Parameters menu in TS, the cylinders in the list to assign to the two separate knock sensors (one for each side of the engine) are only listed as 1-6...can anyone confirm that these are the actual cylinder numbers and not the firing order sequence?
Thanks in advance.
Olivier
Dual WB02 and Knock cylinder questions
