My Configuration (I'll get an MSQ shortly as the car is at another location):
* MS3 running 1.3.2 code
* Car runs on a vapour LPG inject system
* There are two sensors which measures the temperature and pressure of the LPG in the injector fuel rail
* The LPG pressure sensor is a linear 0-5V
* The LPG temperature sensor is a Thermistor (not GM and different to the coolant sensor)
* The LPG pressure & temperature sensors are configured as Generic Sensors in Tuner Studio
* Both sensors are mapped in the Fuel Temperature & Fuel Pressure Adjustment sections in Tuner Studio
My problem is as follows:
* I can easily apply the linear transformation to the LPG pressure sensor - Fuel Pressure Adjustment working OK
* I can't apply a transformation to my LPG temperature sensor - It isn't any of the default types in the transformation pull down menu
I have looked into the custom.ini approach for a variety of my other thermistor type sensors (see below):
Code: Select all
[OutputChannels]
LPGTemp = { 0.000182 * sensor02 * sensor02 - 0.262242 * sensor02 + 100.71 }, "°C" ; ADC to Temp conversion from EGO2 port on MS3X connector
TransOilTemp = { 0.00018 * sensor05 * sensor05 - 0.26634 * sensor05 + 115.87197 }, "°C" ; ADC to Temp conversion from JS4 port on MS3 connector
EngOilTemp = { 0.00018 * sensor06 * sensor06 - 0.26634 * sensor06 + 115.87197 }, "°C" ; ADC to Temp conversion from TinyIOx AD0 port
[GaugeConfigurations]
gaugeCategory = "Custom Gauges"
;Name Var Title Units Lo Hi LoD LoW HiW HiD vd ld
LPGTempGauge = LPGTemp, "LPG Gas Temp", "°C", 0, 100, 5, 10, 80, 90, 0, 0
TransOilTempGauge = TransOilTemp, "Trans Oil Temp", "°C", 0, 100, 10, 20, 80, 90, 0, 0
EngOilTempGauge = EngOilTemp, "Engine Oil Temp", "°C", 0, 100, 10, 20, 80, 90, 0, 0
The process all came undone when I went to program the curve for the fuel temperature adjustment. The value that was being looked up here was the ADC 10bit (0-1023) value and not the degC value calculated in custom.ini. So obviously the custom.ini configuration is limited to the gauges only which makes sense.
For a solution I tried to simply code the fuel temperature adjustment table in the raw ADC numbers (0-1023). However as soon as I tried to put in a number greater than 120 it threw an error message about entering a temperature that was too high. I tried searching through the controller ini file to change this set point (clthighlim) but it didn't work.
So I now need help. How can I achieve what I am trying to do? Below are the options I can think of:
1. Change the default transformation in the MS3 for "Same as MAF" to what I need - I don't use a MAF so if it can be changed to the right curve it would be useful. However, I don't know how to change this transformation as TunerStudio only gives me access to the Coolant and Air temperature calibrations
2. Add another transformation option into the pull down list - I couldn't find anywhere in the controller ini file that does this. I suspect the information is all coded into MS3?
2. I apply a Linear calibration which divides the raw number by 10 (0-1023 to 0-102.3) - This would work because it stays below 120, but I loose resolution because the temperature adjustment table does not allow decimals to be entered for temperature and I Really don't want to do that because it is a critical value
Any help??
Thanks,
Stirling
