Hi, I am about to pull the trigger, and buy a MS3PRO. I know for my current engine, it is way overkill, but I am looking at future proofing my EMS for pretty much any engine I put in this car.
Currently, I have an 85 Mustang GT with an 87 Ford Turbocoupe 2.3T engine, with the T5 transmission. The engine has some upgrades, and mods, so here is my list:
80# high imp injectors
LS2 Truck Coils
Holset HY35
Now, what I am planning on doing... I am looking at replacing the CLT and IAT sensors with the GM ones (I like the weatherpack connectors), but keeping the stock TPS and IAC. I would like to add another air temp sensor (pre intercooler), and eventually some EGT sensors (maybe 1 per cylinder, and then post turbo?), and with that, would I need another module? I have an Innovate LC2 wideband, and all my gauges are Speedhut Revolution gauges, so I would love to be able to monitor/datalog the fuel pressure, oil temp, and oil pressure as well (should I be able to split the signal?), and for the big one... the transmission has VSS as well, can I add that as well?
I've also been reading though a few things, and I think that I can also have some outputs, to turn on a CEL, turn off the alternator under certain conditions and turn on a light? as well as the rad fan control. I also want to have launch control, boost control, table switching as well.
Do I have enough I/O to support this list? Is there anything else I should be looking at adding? am I wishing for too much?
Thanks!
MS3PRO Pre-Purchase Questions....
Re: MS3PRO Pre-Purchase Questions....
You have enough for everything but the 5x egt. Easiest way to get that is the Can-Egt and can be added later.
Kewl. I am just about ready to make the purchase!
