Perhaps on wrong phase? Try adding 360 to tooth#1 angle.Nitroking wrote:The cam just has one tooth with falling edge but on falling edge mode it won't run..
If they are on the same phase and you are using the rising or falling options then it won't make any difference.Nitroking wrote:This log contains cranking lost sync.
I was wondering.. If the real correct tooth is 26 and it reads it once during cranking, does it ignore the rest of the cam signal, so if 14 is wrong it just continues to be wrong until a lost sync occurs? Then still my setup is wrong..
This fixed my faulty setting toojsmcortina wrote:Perhaps on wrong phase? Try adding 360 to tooth#1 angle.Nitroking wrote:The cam just has one tooth with falling edge but on falling edge mode it won't run..
