Malta MX-5 VVT MS3X Settings
Hi
Just about to drop my MX-5 BP-Z3 engine into my kit car and start wiring up my MS3x and wanted to just check that I had the right set up to get started. I'm going for fully sequential without wasted spark.
So its a Malta MX-5 1.8 VVT 2004 engine with Toyota Coil on plugs 90919 02239, GM open element IAT sensor and A wideband O2 sensor. Using the stock can and crank sensors. MS3X V3 board.
So on the board itself:
Solderd a link between VRIN and TACHSELECT
Solder a link between VrOUT and TSEL
JP7 is not jumpered
Tuning settings:
Spark mode = Miata 99-05 ( Will this work with the VVT )
Trigger angle/offset = 0
Ignition input capture = Rising Edge
Spark output = Going High
Number of coils = Coil on Plug
If anybody knows if this is right that would be great.
Many Thanks
Andrew
JP7 is not jumpered
Tuning settings:
Many Thanks
Andrew
Re: Malta MX-5 VVT MS3X Settings
Yes, '99-'05 Miata mode is what you want for the VVT motors.
You do need pull ups on these sensors.
Matt Cramer wrote:Yes, '99-'05 Miata mode is what you want for the VVT motors.
Hi Matt
Thanks for the reply
Is it the camshaft and crank sensors I need to put pull ups on Its just the camshaft and crank sensors only have 3 wires so do you put a 1k resistor in the signal wire
Your trigger angle/offset will very likely be something around 5° - +/-1° but you need to verify this when the engine is running.
fun is not a straight line
Sven
Sven
General sensor wiring instructions are covered in the MS3X Hardware manual.
Thank you for the tip Zaphod I'll start at 5° and go from there.Zaphod wrote:Your trigger angle/offset will very likely be something around 5° - +/-1° but you need to verify this when the engine is running.
Hi Jamesjsmcortina wrote:General sensor wiring instructions are covered in the MS3X Hardware manual.
I've had a look at the manual and tested the cam sensor and it gives off a good 5v trigger so that's fine but the crank sensor gives off around 0.6v so ill need a pull up on it. The reason I ask the question is that the manual doesn't show how to wire a pull up on a 3 wire sensor only a 4 but it does show a diagram of a 3 wire sensor with a pull up built in.
Ive added a diagram how I think it should be done but I'm not 100% sure its right.
Many thanks
Andrew
Right, I don't know if the above pull up wiring diagram will work.
But I found this on the DIY Auto tune website
The CKP input also needs a pull up. You can either put this in place externally or internally.
For an external pull up, run a 1K resistor from pin 26 to pin 24 on the main board.
For an internal pull up on a V3.0 board, connect a 1K resistor on a wire from the 5V hole above the proto area to TachSelect.
For an internal pull up on a V3.57 board, solder a 1K resistor to R57.
https://www.diyautotune.com/support/tec ... our-miata/
It also says
For a pull up on the CMP input, make sure JP7 is in place on the MS3X.
But does anyone know if this is the case with the later cam sensor ? or does something else need to be done.
Cheers
Andrew
It also says
Cheers
Andrew
The later cam sensors use the same pull up.
