Looking for clarification on the switch input for traction control...is it similar to launch where it needs to see ground the entire time it's enabled? The very specific switch I want to use is a momentary (factory button with logo on C6 vette), and wondering if it sending a momentary ground signal to the input would toggle the TC on or off. Otherwise I'll setup a latching relay to allow me to use the button to toggle the relay on and off, thus giving signal to the TC input on the MS3.
Thanks in advance!
Traction control input
Re: Traction control input
It looks like a temporary button - ON while held down. You -can- set it to 'Always on' by setting [Enable on] to "Off"; not sure if that's actually desirable for 99% of the planet ...
