A bit of a newbe question....
I have a home brew turbo ford modular 4.6 v8, I'd like to run 8 injectors on pump gas, normal location (larger in size).
Then I'd like to run a 2nd alcohol fuel system with a couple large injectors up-stream.
Ideally like like to switch between the maps and fuel systems based on boost pressure.
Am I barking up the wrong tree ?? Any advice appreciated.
-p
Multi-Fuel EFI setup
Re: Multi-Fuel EFI setup
It sounds like what you're looking for is the staged injection feature.
I do just this. I stage in from pump fuel to 116 race fuel. It's better staging using table staging. I work from about 140kpa start to 200kpa fully staged. Works great
