Going through my tune before putting the MS3 into the car (haven't started yet) and noticed the AFR Table Load are set to "Use primary load (algorithm )" I am comparing my tune to another experienced user with the same engine and his is set to MAP. I tried searching and tried the TS "?" but couldn't come up with a solid answer what this should be set at.
Any help appreciated.
My setup MS3 3.0 MS3x, Ford stock 2003 4.6 cobra motor (supercharged, VR crank/cam, COP) Wideband O2
Attached my WIP msq
AFR Table Load settings (default)?
MS-III 3.0, MS3x
65 Cobra Daytona FFR, Terminator 4.6 4v, TKO 600
Re: AFR Table Load settings (default)?
Primary load algorithm probably is MAP (Speed density.)
So if both of those are options and Im using SpeedDensity best option is primary load?
Under General settings the AFR table Load options are;
1. Use primary load (algorithm)
2. MAP
3. % Baro
4. TPS
5. MAF
6. ITB
2. MAP
3. % Baro
4. TPS
5. MAF
6. ITB
MS-III 3.0, MS3x
Yes.
James, I have also questioned this. I'm using itb but left it on primary load agurithim. Is that fine or should I change it to itb as well? This thread is a little unclear to me...jsmcortina wrote:Yes.
Sent from my SCH-I545 using Tapatalk
Ask yourself this - "What is your primary load algorithm"
