I want to set up a simple TC for my drag car. I have read some on the perfect run settings and I think that will work. Can I use a DIY hall sensor and a drive shaft sensor wheel to get my driveshaft speed for the perfect run to plot to? If so it looks like I just select the input my sensor is connected to and config from there? Anyone using this can you offer suggestions? Thanks.
Sent from my SM-N920P using Tapatalk
A couple traction control questions....
Re: A couple traction control questions....
That sensor arrangement will work as long as the driveshaft wheel uses teeth instead of magnets.
Can I use one of the 4" missing tooth wheels off the site or does it have to have all teeth?
It needs to be a non-missing-tooth wheel.
Thanks Jimmy
