Hi!
Previously running engine on MS3X. 2.0 inline 4 turbocharged. Hall sensors, 60-2 crank and a single tooth cam.
Upgraded firmware to 1.4.1 from something very old - and have no old msq file.
I am not able to remember - should I select in the trigger wheel settings dialog - dual wheel, with this setup? - or should I use single wheel with missing teeth?
Fredrik,
MS3X Single or Dual wheel for sequential
Re: MS3X Single or Dual wheel for sequential
dual wheel with missing tooth
Thank you!
