grom_e30 wrote:and you are powering it off the tps vref? what voltage do you measure on the signal pin? what pin is connected to the signal?
Yes, Ground is to the MS, 5v is the same as the TPS, and MAP_EXT is the signal
grom_e30 wrote:do the rest of the injectors work in test mode? seems odd only 1 works during cranking
All great suggestions thanks, Hope to hit it hard this weekend.billr wrote:I would focus on the flaky MAP signal. That should be easiest to trouble-shoot. Once you find/fix the problem there, everything else might get "healed" too. First, connect a simple vacuum gauge to the intake. Let's see if the MAP really is going terribly low. Like others, I doubt it, but it is so easy to check. Assuming the manifold vacuum is low (MAP high) during cranking, then we move on to electrical tests with voltmeter. Sensor 5V to sensor ground, sensor ground to chassis/MS ground, sensor signal to sensor ground; all those while the engine is cranking.
I have them split between two fuses, Bank A and B. Both fuses were crapgrom_e30 wrote:glad you got it sorted, 8 injectors powered off the same feed? if so id go 10-15 amp fuse wise
