ego over can
ego over can
under ego data via can you have the option to select 'innovate format' but what exactly is the ecu expecting to receive? i have read this: http://www.innovatemotorsports.com/supp ... llog-2.pdf and understand how to decode the 6 bytes my lc1 spits out as a serial packet is it just a case of sending those 6 bytes over can bus to the ms3 when there is a msg request for them?
Re: ego over can
Actually, it is the Innovate raw Lambda value from word 1 (section 2.2 in that document) and not the whole Innovate serial format. It also assumes that the AFR multiplier is 14.7. Note that only the 0-1023 range is used.
Re: ego over can
does the lc1 have to be set to out put lambda as opposed to afr
Re: ego over can
No. Leave it in its default state.grom_e30 wrote:does the lc1 have to be set to out put lambda as opposed to afr
