Hi, i'm having troubles to get my car starting using stock harness.
Setup is
box is set up as https://www.diyautotune.com/support/tec ... your-4g63/ for MS3x
Sequential injector / wasted spark
CKP input to VR circuit with 1k ohm resistor
If i follow the Electrical diagram from Mitsubishi the ground for CKP sensor should be Pin 13. However when connected i get no signal to my MS3-
If i run a wire from ground on the sensor to CKP input to MS i get signal in TS but it's very noisy " unshielded ground cable from engine to shielded cable in MS piggy harness.
Also i'm wondering if i could use Alternator control in MS3/MS3x to control the voltage regulator or should i use piggyback and let the stock ECU control this?
I cannot Attach a Datalog or MSQ becuase the computer with that stuff is in my shop.
Best Regards
98 Eclipse GST MS3x 4g63T problems
Re: 98 Eclipse GST MS3x 4g63T problems
SO after some extending research and troubleshooting. i think there are some troubles with my board.
I get a very intermittent signal from the CAS every 5 seconds bt no crank or RPM signal. I.E Not syncing.
I'm sharing the cables from my stock ECU and everything else works fine, all the sensor and everything works like a champ.
I'm thinking of ordering a ms1 v.357 and ask DIYautotune if they could prepare the board for 4g63 CKP and CMP input and then i could just switch out the processor board to my MS3x, do the necesseary jumper mods for stepper IAC. and calibrate the resistor to get a tach signal?
FYI I bought the V3.0 board second hand it's pretty messed up so i think the previous owner has not been so easy on the solder iron.
