MS3X skip pulses problem!
Hi
I run ms3x cop vag 115 cols, inline six.
I have issues with ignition skip pulses.
it does not matter what what I choose for number setting, 2 , 6 or maximum 10, the engine starts immediately after the first lap.
Any ides?
Thanks /Roman
Any ides?
Thanks /Roman
Mercedes 300E Turbo MS3X 1150hp
http://www.turbobandit.com
http://www.youtube.com/user/PUMPISH
https://www.facebook.com/pages/Turboban ... 24?fref=ts
Re: MS3X skip pulses problem!
What trigger pattern are you using? On a 60-2 wheel, 10 skip pulses is only 60 degrees of crank rotation.
I thought the "pulses" were counts of the missing tooth and/or cam sensor? 60º of crankshaft rotation (in even best case scenario) wouldn't reliably let the MegaSquirt know enough to know what injector/coil (pair) to trigger for start up since it wouldn't be very hard to go 60º of rotation without a missing tooth crossing the crank sensor.Matt Cramer wrote:What trigger pattern are you using? On a 60-2 wheel, 10 skip pulses is only 60 degrees of crank rotation.
I believe it skips individual pulses of the sensor, and once the number of pulses has been received, it then tries to establish sync (in the case of a 60-2, by looking for the missing tooth). So 10 skip pulses will delay looking for the missing teeth by 60 crank degrees. Still enough to avoid most random noise.
Ah, I could see that.
The delay is to allow the starter to actually start turning the engine over; the first few teeth are obviously going to be enormously slower than the next many, even if the engine isn't anywhere near full cranking speed yet.
Also - why would you consider the engine starting on the first revolution to be a problem? OEMs spend $$Brazillians to accomplish this reliably ...
